주요 콘텐츠로 건너뛰기
Krups F203 Coffee Grinder Base Plate Replacement
필요한 것
  1. Krups F203 Coffee Grinder Base Plate Replacement, Base Plate: 1 단계, 이미지 1/1
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Base Plate Replacement: 2 단계, 이미지 1/3 Krups F203 Coffee Grinder Base Plate Replacement: 2 단계, 이미지 2/3 Krups F203 Coffee Grinder Base Plate Replacement: 2 단계, 이미지 3/3
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Base Plate Replacement: 3 단계, 이미지 1/2 Krups F203 Coffee Grinder Base Plate Replacement: 3 단계, 이미지 2/2
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Brian Wolfskill
회원 가입일: 10/23/14
420 평판
안내서 1개 작성함
Baylor, Team 4-2, Williams Fall 2014 Baylor, Team 4-2, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G2
3 회원들
안내서 8개 작성하였습니다
댓글 10개
Thanks! I was able to repair my broken cord.
wdswaim - 답글
I'mworking on it as we write .
jerry - 답글
Does anyone have a video tutorial explaining how the heck one removes the base?? I bought a spudger and it still doesn't help. It is awfully hard to loosen up.. I kept trying and trying but I stopped cause I'm concerned I might break the clips and the outside which the plastic is starting to stretch.. the clips are starting to lose their shape as well and worried I might break the spudger... Thanks
NeonAera - 답글
I am having the same experience as NeonAera posted. I could clear 2 of the 4 clips, but not the others and getting the same issue of distorting the outside wall of the base , if I continue to try and pry the clips with the spudger. Thanks
Steve Ferrill - 답글
We had a jammed . I disassembled according to the guide, scraped out the rust I found, lubricated with WD40 and reassembled. Went from not moving to working great. I broke all 4 tabs (guess I lack patience…) but gorilla taped it back together and it's totally solid.
Wade Brainerd - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 16
30일 전: 62
전체 시간: 11,284
