주요 콘텐츠로 건너뛰기
Krups F203 Coffee Grinder Motor Replacement
필요한 것
  1. Krups F203 Coffee Grinder Motor Replacement, Base Plate: 1 단계, 이미지 1/1
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Motor Replacement: 2 단계, 이미지 1/3 Krups F203 Coffee Grinder Motor Replacement: 2 단계, 이미지 2/3 Krups F203 Coffee Grinder Motor Replacement: 2 단계, 이미지 3/3
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Motor Replacement: 3 단계, 이미지 1/2 Krups F203 Coffee Grinder Motor Replacement: 3 단계, 이미지 2/2
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Motor Replacement, Detach Trigger Button from Base Plate: 4 단계, 이미지 1/1
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Motor Replacement: 5 단계, 이미지 1/2 Krups F203 Coffee Grinder Motor Replacement: 5 단계, 이미지 2/2
    • Remove the white trigger.
  6. Krups F203 Coffee Grinder Motor Replacement: 6 단계, 이미지 1/1
    • Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
    • Be sure to reference the how to solder video posted to the device page
  7. Krups F203 Coffee Grinder Motor Replacement, Motor: 7 단계, 이미지 1/1
    • Desolder remaining contact point from the plug cord
  8. Krups F203 Coffee Grinder Motor Replacement: 8 단계, 이미지 1/2 Krups F203 Coffee Grinder Motor Replacement: 8 단계, 이미지 2/2
    • Using a Phillips screwdriver, remove the two screws holding the motor in place.
  9. Krups F203 Coffee Grinder Motor Replacement: 9 단계, 이미지 1/1
    • Remove the motor from the shell.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Ian Hancock
회원 가입일: 10/22/14
414 평판
안내서 3개 작성하였습니다
Baylor, Team 4-2, Williams Fall 2014 Baylor, Team 4-2, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G2
3 회원들
안내서 8개 작성하였습니다
댓글 7개
Doesn’t seem to apply to the Type 203. It looks different.
rpoland - 답글
The first photo of the bottom plate is too dark to show details. I have type 203 B Made in France and the clips didn’t budge without first breaking/stretching the thin outer walls of the base plate. No need to remove the wires. With mine, you have to turn the bottom shaft of the motor with a screwdriver (counter clockwise as usual) while holding the blade stationary which unscrews the blade from the motor enabling you to remove the motor after the two phillips screws are removed.
seeley6 - 답글
Hi Ian!
Nice explanation!
Can you provide a close up of the spudger that you used for opening the bottom plate?
I want to use the correct one, so I don ´t break that aged plastic cover.
Bengt
Yngve Lien - 답글
Where does one get the replacement motor?
Andrea Garrity - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 26
30일 전: 125
전체 시간: 27,274
