소개
Sometimes, the plug or cord attached to the Krups F203 coffee grinder is defective. This guide will tell you how to replace the cord.
필요한 것
In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
The trigger button is held in with light tension clips. Gently pry them back to release.
Use the soldering iron to remove the existing solder.
다른 한 분이 해당 안내서를 완성하였습니다.
