주요 콘텐츠로 건너뛰기
Krups F203 Coffee Grinder Plug/Cord Replacement
필요한 것
  1. Krups F203 Coffee Grinder Plug/Cord Replacement, Base Plate: 1 단계, 이미지 1/1
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Plug/Cord Replacement: 2 단계, 이미지 1/3 Krups F203 Coffee Grinder Plug/Cord Replacement: 2 단계, 이미지 2/3 Krups F203 Coffee Grinder Plug/Cord Replacement: 2 단계, 이미지 3/3
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Plug/Cord Replacement: 3 단계, 이미지 1/2 Krups F203 Coffee Grinder Plug/Cord Replacement: 3 단계, 이미지 2/2
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Plug/Cord Replacement, Detach Trigger Button from Base Plate: 4 단계, 이미지 1/2 Krups F203 Coffee Grinder Plug/Cord Replacement, Detach Trigger Button from Base Plate: 4 단계, 이미지 2/2
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Plug/Cord Replacement, Remove the wire from two contact points: 5 단계, 이미지 1/1
    • Use the soldering iron to remove the existing solder.
    • Be sure to reference the how to solder video posted on the device page.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ian Hancock
회원 가입일: 10/22/14
414 평판
안내서 3개 작성하였습니다
Baylor, Team 4-2, Williams Fall 2014 Baylor, Team 4-2, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G2
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 28
전체 시간: 2,935
