주요 콘텐츠로 건너뛰기
Krups F203 Coffee Grinder Trigger Assembly Replacement
필요한 것
  1. Krups F203 Coffee Grinder Trigger Assembly Replacement, Base Plate: 1 단계, 이미지 1개 중 1개
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Trigger Assembly Replacement: 2 단계, 이미지 3개 중 1개 Krups F203 Coffee Grinder Trigger Assembly Replacement: 2 단계, 이미지 3개 중 2개 Krups F203 Coffee Grinder Trigger Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Trigger Assembly Replacement: 3 단계, 이미지 2개 중 1개 Krups F203 Coffee Grinder Trigger Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Trigger Assembly Replacement, Detach Trigger Button from Base Plate: 4 단계, 이미지 1개 중 1개
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Trigger Assembly Replacement: 5 단계, 이미지 2개 중 1개 Krups F203 Coffee Grinder Trigger Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the white trigger.
  6. Krups F203 Coffee Grinder Trigger Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
    • Be sure to reference the how to solder video posted to the device page
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ian Hancock
회원 가입일: 10/22/14
432 평판
안내서 3개를 작성함
Baylor, Team 4-2, Williams Fall 2014 Baylor, Team 4-2, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G2
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 24
전체 시간: 5,817
