소개
Removing the back cover allows easy access to many components inside of the device allowing you to fix other issues that may have popped up. This guide will show you how to remove your back cover and replace it if desired.
필요한 것
Turn the device over and place it with the screen down on a flat surface that is clean so the screen does not get scratched.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
