소개
The motherboard contains all of the electronics, and most of the components of your device. Replacing the motherboard can fix many different issues that may come up with your device, as well as let you access all of the components in your device. This guide will walk you through the steps to access the motherboard and replace it if necessary.
필요한 것
Turn the device over and place it with the screen down on a flat surface that is clean so the screen does not get scratched.
다른 2명이 해당 안내서를 완성하였습니다.
