주요 콘텐츠로 건너뛰기
Kurio 10S Speakers Replacement
필요한 것
  1. Kurio 10S Speakers Replacement, Back Cover: 1 단계, 이미지 1/1
    • Turn the device over and place it with the screen down on a flat surface that is clean so the screen does not get scratched.
  2. Kurio 10S Speakers Replacement: 2 단계, 이미지 1/2 Kurio 10S Speakers Replacement: 2 단계, 이미지 2/2
    • Locate the four screws, two on each side.
    • Using the philips head screwdriver, carefully remove each screw and keep them together in a safe location.
  3. Kurio 10S Speakers Replacement: 3 단계, 이미지 1/1
    • Once all screws are removed, use a spudger to get under a corner and unclip the hooks.
    • Once the spudger is under the cover, slide it all the way around the device, pushing lightly into the device making sure it stays under the cover until all the clips are removed.
    • The back cover is difficult to remove, so do not be afraid of using some force once all of the clips have been removed.
  4. Kurio 10S Speakers Replacement: 4 단계, 이미지 1/1
    • The back cover should then be able to easily be removed from the device and you should see the battery and other internal components.
  5. Kurio 10S Speakers Replacement, Speakers: 5 단계, 이미지 1/1
    • Locate the two speakers on either side of the device
  6. Kurio 10S Speakers Replacement: 6 단계, 이미지 1/2 Kurio 10S Speakers Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Carefully disconnect the black and red wire from the motherboard using tweezers
    • Caution: motherboard parts are very fragile, so be careful when removing the wires
  7. Kurio 10S Speakers Replacement: 7 단계, 이미지 1/1
    • Remove the speaker from its holder.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Hanna Desilets
회원 가입일: 03/25/15
122 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-6, Shastany Spring 2015 UMass Dartmouth, Team 1-6, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S1G6
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
This tutorial was veryhelpful
Ralph Watson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 7
전체 시간: 228
