주요 콘텐츠로 건너뛰기
Kurio 7 Screen Replacement
필요한 것
  1. Kurio 7 Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Kurio 7 Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Kurio 7 Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Begin by removing the rubber cover from the Kurio 7.
  2. Kurio 7 Screen Replacement: 2 단계, 이미지 2개 중 1개 Kurio 7 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four 30 mm Phillips #00 screws from the outer case.
  3. Kurio 7 Screen Replacement: 3 단계, 이미지 2개 중 1개 Kurio 7 Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
    • Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
    • Be careful not to break off the tabs that hold the front cover and the back cover together.
  4. Kurio 7 Screen Replacement: 4 단계, 이미지 2개 중 1개 Kurio 7 Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Once all of the tabs are removed, the back cover should come off easily.
    • Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
  5. Kurio 7 Screen Replacement, Kurio 7 Motherboard Removal Guide: 5 단계, 이미지 2개 중 1개 Kurio 7 Screen Replacement, Kurio 7 Motherboard Removal Guide: 5 단계, 이미지 2개 중 2개
    • Use a plastic credit card, or other thin object, to separate the battery from the screen.
    • Be sure to work the card carefully and slowly around in order to not damage, break, or deform the battery.
    • Carefully set the battery aside.
  6. Kurio 7 Screen Replacement: 6 단계, 이미지 2개 중 1개 Kurio 7 Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the eight 40mm screws holding the motherboard in place.
  7. Kurio 7 Screen Replacement: 7 단계, 이미지 3개 중 1개 Kurio 7 Screen Replacement: 7 단계, 이미지 3개 중 2개 Kurio 7 Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Place the plastic opening tool on the base of the black ribbon clip and pull up, like a lever, to release the mount. This should release the clip holding the ribbon to the mount.
    • Pull the ribbon out of the mount.
  8. Kurio 7 Screen Replacement: 8 단계, 이미지 1개 중 1개
    • There should be masking tape on the yellow ribbon. Pull the tape off of the motherboard and wrap it around the yellow ribbon.
    • Do not pull the tape completely off the motherboard, as it is used to protect components on the ribbon.
    • To remove the ribbon from the mount, follow the same steps in Step 3.
  9. Kurio 7 Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Pull back the ribbons and put the battery near the bottom of the Kurio.
    • The motherboard is now removed so that other components can be worked on.
  10. Kurio 7 Screen Replacement, Screen: 10 단계, 이미지 1개 중 1개
    • Flip motherboard down near base of device.
    • Be careful not to pull out any wires when moving the motherboard.
  11. Kurio 7 Screen Replacement: 11 단계, 이미지 3개 중 1개 Kurio 7 Screen Replacement: 11 단계, 이미지 3개 중 2개 Kurio 7 Screen Replacement: 11 단계, 이미지 3개 중 3개
    • This is tricky, and an extra pair of hands may help. Use the opening tool to pry the screen out from underneath the tabs holding it in place.
    • Once you have created some space between the screen and the cover, slide the opening tool under the screen.
    • Slide the opening tool around the outside of the screen, releasing the tabs as you go along.
    • Be careful not to pull too hard on the motherboard while doing this, as there are still many wires attached to the body of the device.
  12. Kurio 7 Screen Replacement: 12 단계, 이미지 3개 중 1개 Kurio 7 Screen Replacement: 12 단계, 이미지 3개 중 2개 Kurio 7 Screen Replacement: 12 단계, 이미지 3개 중 3개
    • Pull the screen out from the casing.
    • You have successfully removed the screen!
결론
Replace with new screen. Reassemble by completing the steps in reverse order.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Eric Rice
회원 가입일: 04/14/14
913 평판
안내서 3개를 작성함
Cal Poly, Team 12-36, Maness Spring 2014 Cal Poly, Team 12-36, Maness Spring 2014 회원
CPSU-MANESS-S14S12G36
4 회원들
안내서 14개를 작성함
4가이드 댓글
Hey Eric.
Nice guide with Pro-tricks.
Maybe you can tell me, where to buy new LCD-screen for Kurio 7S C13000
I've been Googled all places, but haven't found anything.
Hope to hear from you.
Please send a mail at us.oerbaek@gmail.com
Thanks a lot.
Mr. Skott, Denmark
Ulrich Juul - 답글
Hi can you fix the kurio watch? My son got one for Christmas and broke it already. He has cracked the screen top half won't work but the bottom still works you can see everything still on the screen.
If anyone has any help could you email me please nchambers1@hotmail.co.uk
Nick chambers - 답글
Hello, my son has a kurio table and the screen is crack. Would you be able to fix it for me if I get all the parts. My email is uriyah29@yahoo.com. Thank you
taniao129 - 답글
Hello, I’m Jeremy. I have a Kurio 7s that screen has cracked. It used to wor, but progressively got worse. I used to not be able to get past the home screen. Now, it doesnt turn on and even if charged it always says low battery. If you can fix this, my email is germookd@gmail.com
2024_Jeremy Norris - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 19
지난 30일: 104
전체 시간: 49,991
