주요 콘텐츠로 건너뛰기
Kurio Touch 4S Front & Rear Facing Cameras Replacement
필요한 것
  1. Kurio Touch 4S Front & Rear Facing Cameras Replacement, Front & Rear Facing Cameras: 1 단계, 이미지 1/1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 2 단계, 이미지 1/3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 2 단계, 이미지 2/3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 2 단계, 이미지 3/3
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 3 단계, 이미지 1/3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 3 단계, 이미지 2/3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 3 단계, 이미지 3/3
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
  4. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 4 단계, 이미지 1/1
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you miss them up.
  5. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 5 단계, 이미지 1/1
    • Remove the battery because it blocks the plastic shield that covers the camera.
    • Do not remove the wires that are attached to the battery and the motherboard.
  6. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the plastic cover that is covering the camera area using tweezers.
  7. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 7 단계, 이미지 1/2 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 7 단계, 이미지 2/2
    • Separate the two halves of your Kurio Touch 4S.
    • Gently use a brush to remove any dirt or finger prints around the area.
    • Use the Tweezers to detach the front and back camera from its place.
  8. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 8 단계, 이미지 1/2 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 8 단계, 이미지 2/2
    • Remove the copper wires by using the Tweezers to replace your new camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Khalid AlTamimi
회원 가입일: 01/21/15
275 평판
안내서 2개 작성하였습니다
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015 회원
USFT-BROWN-W15S6G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 248
