주요 콘텐츠로 건너뛰기
Kurio Touch 4S Front & Rear Facing Cameras Replacement
필요한 것
  1. Kurio Touch 4S Front & Rear Facing Cameras Replacement, Front & Rear Facing Cameras: 1 단계, 이미지 1개 중 1개
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 2 단계, 이미지 3개 중 1개 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 2 단계, 이미지 3개 중 2개 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 2 단계, 이미지 3개 중 3개
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 3 단계, 이미지 3개 중 1개 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 3 단계, 이미지 3개 중 2개 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 3 단계, 이미지 3개 중 3개
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
  4. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 4 단계, 이미지 1개 중 1개
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you miss them up.
  5. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the battery because it blocks the plastic shield that covers the camera.
    • Do not remove the wires that are attached to the battery and the motherboard.
  6. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the plastic cover that is covering the camera area using tweezers.
  7. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 7 단계, 이미지 2개 중 1개 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 7 단계, 이미지 2개 중 2개
    • Separate the two halves of your Kurio Touch 4S.
    • Gently use a brush to remove any dirt or finger prints around the area.
    • Use the Tweezers to detach the front and back camera from its place.
  8. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 8 단계, 이미지 2개 중 1개 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the copper wires by using the Tweezers to replace your new camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Khalid AlTamimi
회원 가입일: 01/21/15
275 평판
안내서 2개를 작성함
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015 회원
USFT-BROWN-W15S6G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 317
