주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kurio Touch 4S Power Button Replacement
필요한 것
  1. Kurio Touch 4S Power Button Replacement, Power Button: 1 단계, 이미지 1개 중 1개
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Power Button Replacement: 2 단계, 이미지 3개 중 1개 Kurio Touch 4S Power Button Replacement: 2 단계, 이미지 3개 중 2개 Kurio Touch 4S Power Button Replacement: 2 단계, 이미지 3개 중 3개
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Power Button Replacement: 3 단계, 이미지 2개 중 1개 Kurio Touch 4S Power Button Replacement: 3 단계, 이미지 2개 중 2개
    • To remove the battery, make sure the four 5mm Phillips screws on each side of your device is open using the Phillips #1 Screwdriver
    • After you remove your four 5mm Phillips screws, use your plastic opening tool to help you open the plastic cover of your device.
  4. Kurio Touch 4S Power Button Replacement: 4 단계, 이미지 1개 중 1개
    • After you remove your four 5mm Philips screws use your plastic opening tool to help you open the plastic cover of your device.
  5. Kurio Touch 4S Power Button Replacement: 5 단계, 이미지 1개 중 1개
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  6. Kurio Touch 4S Power Button Replacement: 6 단계, 이미지 1개 중 1개
    • Gently remove the plastic cover that is covering the camera.
  7. Kurio Touch 4S Power Button Replacement: 7 단계, 이미지 1개 중 1개
    • Use Phillips # 1 screw to open the four 5mm Philips screws on the motherboard.
    • Open the screws gently and do not apply too much force as you could damage the motherboard.
  8. Kurio Touch 4S Power Button Replacement: 8 단계, 이미지 1개 중 1개
    • Use the plastic opener to remove the battery.
  9. Kurio Touch 4S Power Button Replacement: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to remove the black tape that is attached to the motherboard.
  10. Kurio Touch 4S Power Button Replacement: 10 단계, 이미지 2개 중 1개 Kurio Touch 4S Power Button Replacement: 10 단계, 이미지 2개 중 2개
    • Detach all the wire that are connected to the motherboard.
    • Detach the camera module and other components that are attached to the motherboard.
  11. Kurio Touch 4S Power Button Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the motherboard with the help of plastic opener.
    • Detach the power plug before you remove the motherboard.
  12. Kurio Touch 4S Power Button Replacement: 12 단계, 이미지 1개 중 1개
    • Use tweezers to hold the power button and gently lift it up.
    • Replace the old power button with the new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Moin Khan
회원 가입일: 01/21/15
234 평판
안내서 2개를 작성함
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015 회원
USFT-BROWN-W15S6G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 18
전체 시간: 601
