주요 콘텐츠로 건너뛰기
Kurio Xtreme Back Panel Replacement
필요한 것
  1. Kurio Xtreme Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Back Panel Replacement: 2 단계, 이미지 1/2 Kurio Xtreme Back Panel Replacement: 2 단계, 이미지 2/2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Back Panel Replacement: 3 단계, 이미지 1/3 Kurio Xtreme Back Panel Replacement: 3 단계, 이미지 2/3 Kurio Xtreme Back Panel Replacement: 3 단계, 이미지 3/3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mallory Myers
회원 가입일: 09/22/15
1,190 평판
안내서 7개 작성하였습니다
Baylor, Team 6-10, Williams Fall 2015 Baylor, Team 6-10, Williams Fall 2015 회원
BU-WILLIAMS-F15S6G10
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 461
