주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
소개
If one or both of the cameras in your Kurio Xtreme are broken, follow this guide to replace them. The front and back cameras are connected, so you will be replacing both of them, even if only one is broken.
부품
지정된 부품이 없습니다.
  1. Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Unscrew the four 4 mm black screws using a Phillips #000 screw driver. There are two screws on each side of the device (four total).
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Insert the plastic opening tool in between the edges of the blue front casing and black back casing. Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device. Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Remove the flat-topped connector that connects the cameras to the motherboard by using the plastic opening tool to pry up on each side.
    • Remove the flat-topped connector that connects the cameras to the motherboard by using the plastic opening tool to pry up on each side.
  5. Remove the smaller, front facing camera by lifting up on the attached ribbon cable. Remove the larger, rear facing camera by lifting up on the attached ribbon cable. Remove the larger, rear facing camera by lifting up on the attached ribbon cable.
    • Remove the smaller, front facing camera by lifting up on the attached ribbon cable.
    • Remove the larger, rear facing camera by lifting up on the attached ribbon cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mallory Myers
회원 가입일: 2015년 09월 22일
1,109 평판
안내서 7개 작성하였습니다
Baylor, Team 6-10, Williams Fall 2015 Baylor, Team 6-10, Williams Fall 2015 회원
BU-WILLIAMS-F15S6G10
3 회원들
안내서 14개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 105
