주요 콘텐츠로 건너뛰기
Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement)
  1. Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement), Head and Handle (Shona): 1 단계, 이미지 1/2 Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement), Head and Handle (Shona): 1 단계, 이미지 2/2
    • Ona kuti pombi inoshanda zvakanaka sei nekupomba kwemakumi mana.
    • Pombi inoshanda zvakanaka inofanira kudira mvura inosvika marita gumi.
  2. Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 2 단계, 이미지 1/2 Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 2 단계, 이미지 2/2
    • Bvisa mapini maviri akabatanidza mubato nechinofambisa mubato.
  3. Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 3 단계, 이미지 1/2 Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 3 단계, 이미지 2/2
    • Dhonza mibato miviri kubva kune chinofambisa mubato.
  4. Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 4 단계, 이미지 1/2 Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 4 단계, 이미지 2/2
    • Simudza mapini maviri akabatanidza pombi kumusoro nemubato, kubva papombi.
  5. Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 5 단계, 이미지 1/3 Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 5 단계, 이미지 2/3 Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 5 단계, 이미지 3/3
    • Mudanho rino rose, ona kuti watsigira mubato nemusoro nemaoko matatu kana kupfuura.
    • Buritsa chimutanda chejoinhi kubva muchimusoro.
    • Wongorora chimutanda chejoinhi nemusoro kuti hazvina kusakara kana kukuvara here.
  6. Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 6 단계, 이미지 1/1
    • Bvisa musoro nemubato wozviisa panzvimbo yakachena kuti zvisabate utachiona
  7. Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement), Riser Main Slider (Shona): 7 단계, 이미지 1/2 Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement), Riser Main Slider (Shona): 7 단계, 이미지 2/2
    • Simudza mubato mukuru unosimudza pombi zvine simba nemaoko maviri.
    • Chenjerera kuti usadonhedze mubato mukuru unosimudza pombi, nekuti izvi zvinogona kukuvadza humburumbira
  8. Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 8 단계, 이미지 1/3 Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 8 단계, 이미지 2/3 Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 8 단계, 이미지 3/3
    • Shandisa chipanera chepombi kusunungura pombi inotakura mvura yepamusoro.
  9. Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 9 단계, 이미지 1/3 Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 9 단계, 이미지 2/3 Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 9 단계, 이미지 3/3
    • Simudza mubato unosimudza pombi nepombi refu.
    • Tenderedza simbi inobata chimutanda chepombi pachimutanda, uye chisunge zvine simba pachimutanda chepombi.
    • Dzikisa pombi refu nemubato unosimudza pombi kuti ugare pane chinobatisa pombi zvakanaka.
  10. Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 10 단계, 이미지 1/3 Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 10 단계, 이미지 2/3 Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 10 단계, 이미지 3/3
    • Sunungura ubvise bhaudhi rinobata chimutanda chepombi nebhaudhi rechimutanda chepombi pamusoro pemutanda unosimudza pombi.
  11. Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 11 단계, 이미지 1/2 Kutsiva Mubato Mukuru Unosimudza Mvura Wepombi Inodhonza Mvura YeBush (Bush Pump Riser Main Slider Replacement): 11 단계, 이미지 2/2
    • Bvisa mubato mukuru unosimudza pombi, uye ongorora kuti haina kubvaruka kana kuchembera here.
    • Isa mubato unosimudza pombi panzvimbo yakachena kuitira kuti usabate utachiona.
결론
Kuti ubatanidze mudziyo wako zvakare, tevedzera mirayiro uchitanga nekwekupedzesera.
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 175
