주요 콘텐츠로 건너뛰기
Kwikset 450248 Battery Replacement
필요한 것
  1. Kwikset 450248 Battery Replacement, Battery: 1 단계, 이미지 1/2 Kwikset 450248 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Ensure you are changing the batteries on this model of the Kwikset digital door lock.
    • Prepare your AA batteries and flat head screwdriver before changing the battery.
  2. Kwikset 450248 Battery Replacement: 2 단계, 이미지 1/3 Kwikset 450248 Battery Replacement: 2 단계, 이미지 2/3 Kwikset 450248 Battery Replacement: 2 단계, 이미지 3/3
    • Use your flathead screwdriver to pry your Kwikset door lock cover open.
    • Push up on the cover.
    • Slide the cover up to display the battery storage area.
  3. Kwikset 450248 Battery Replacement: 3 단계, 이미지 1/2 Kwikset 450248 Battery Replacement: 3 단계, 이미지 2/2
    • Grab the top of the battery storage area.
    • Pull the battery storage area out of the device.
  4. Kwikset 450248 Battery Replacement: 4 단계, 이미지 1/2 Kwikset 450248 Battery Replacement: 4 단계, 이미지 2/2
    • Remove all four batteries from the battery storage area.
    • Open the battery package and take four batteries out.
    • Place the new batteries into the battery storage area.
  5. Kwikset 450248 Battery Replacement: 5 단계, 이미지 1/1
    • Put the battery storage device back into the Kwikset door lock.
    • Ensure the yellow label is facing you.
  6. Kwikset 450248 Battery Replacement: 6 단계, 이미지 1/1
    • Slide the cover back onto the Kwikset digital door lock.
결론
To ensure that the Kwikset digital door lock is reassembled properly turn the lock, and listen for the door lock to state door locked or door unlocked.
Taylor S. Matthews
회원 가입일: 09/28/21
133 평판
안내서 1개 작성함
UNT-Martin-F23S1G14 UNT-Martin-F23S1G14 회원
Community
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 71
전체 시간: 273
