주요 콘텐츠로 건너뛰기
Kyocera Echo Flash and Motherboard Replacement
필요한 것
  1. Kyocera Echo Flash and Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Orient the phone so that the screen is face down.
    • Place one or both thumbs near the small arrow at the bottom of the phone and firmly push the cover up.
  2. Kyocera Echo Flash and Motherboard Replacement: 2 단계, 이미지 1/1
    • Pull up on the back cover and lift the top to separate it from the phone.
  3. Kyocera Echo Flash and Motherboard Replacement: 3 단계, 이미지 1/1
    • Pull the battery out of the device with a thin object such as your nail or credit card.
  4. Kyocera Echo Flash and Motherboard Replacement, Flash and Motherboard: 4 단계, 이미지 1/1
    • Unscrew four 4.3mm Phillips #000 screws.
  5. Kyocera Echo Flash and Motherboard Replacement: 5 단계, 이미지 1/1
    • Unscrew 2 Y1000 4.8 mm screws.
  6. Kyocera Echo Flash and Motherboard Replacement: 6 단계, 이미지 1/2 Kyocera Echo Flash and Motherboard Replacement: 6 단계, 이미지 2/2
    • Wedge a plastic opening tool under the black outer casing of the phone. Push the plastic opening tool down and outward while rotating the phone to pry the black outer casing off.
    • Do not apply too much pressure to the outer casing, as it could damage internal components.
  7. Kyocera Echo Flash and Motherboard Replacement: 7 단계, 이미지 1/1
    • Wedge a plastic opening tool under the motherboard directly above the flash. Additionally, use a plastic opening tool to unhook corner labeled in a red square.
  8. Kyocera Echo Flash and Motherboard Replacement: 8 단계, 이미지 1/2 Kyocera Echo Flash and Motherboard Replacement: 8 단계, 이미지 2/2
    • Gently pull the motherboard out of its compartment.
결론
Alex Kinstedt
회원 가입일: 11/05/18
483 평판
안내서 4개 작성하였습니다
IUPUI, Team S2-G6, Baechle Fall 2018 IUPUI, Team S2-G6, Baechle Fall 2018 회원
IUPUI-BAECHLE-F18S2G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 8
전체 시간: 181
