주요 콘텐츠로 건너뛰기
Kyocera Event Camera Lens Replacement
필요한 것
  1. Kyocera Event Camera Lens Replacement, Camera Lens: 1 단계, 이미지 1/3 Kyocera Event Camera Lens Replacement, Camera Lens: 1 단계, 이미지 2/3 Kyocera Event Camera Lens Replacement, Camera Lens: 1 단계, 이미지 3/3
    • Flip phone over and remove back cover
  2. Kyocera Event Camera Lens Replacement: 2 단계, 이미지 1/1
    • Use the screwdriver with the Y0 bit attached to take out the seven 5mm screws that attach the back cover on the phone. Make sure to keep track of these screws, as they are pretty important.
  3. Kyocera Event Camera Lens Replacement: 3 단계, 이미지 1/1
    • Next, use the metal spudger to pry at the plastic clips. Be careful to not to lose the power button and volume buttons as they fall out. Remove the plug for the camera flash.
  4. Kyocera Event Camera Lens Replacement: 4 단계, 이미지 1/3 Kyocera Event Camera Lens Replacement: 4 단계, 이미지 2/3 Kyocera Event Camera Lens Replacement: 4 단계, 이미지 3/3
    • Use the spudger to pry the camera lens and remove it from the rear frame. Then you can replace the lens.
결론
ryan
회원 가입일: 03/16/15
221 평판
안내서 1개 작성함
Colorado Springs, Team 1-2, May Spring 2015 Colorado Springs, Team 1-2, May Spring 2015 회원
UCCS-MAY-S15S1G2
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,458
