주요 콘텐츠로 건너뛰기
Kyocera Event Ear Piece Speaker Replacement
필요한 것
  1. Kyocera Event Ear Piece Speaker Replacement, Battery: 1 단계, 이미지 1/3 Kyocera Event Ear Piece Speaker Replacement, Battery: 1 단계, 이미지 2/3 Kyocera Event Ear Piece Speaker Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Ear Piece Speaker Replacement: 2 단계, 이미지 1/1
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event Ear Piece Speaker Replacement, Remove the screws.: 3 단계, 이미지 1/2 Kyocera Event Ear Piece Speaker Replacement, Remove the screws.: 3 단계, 이미지 2/2
    • Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
  4. Kyocera Event Ear Piece Speaker Replacement, Remove the back assembly: 4 단계, 이미지 1/3 Kyocera Event Ear Piece Speaker Replacement, Remove the back assembly: 4 단계, 이미지 2/3 Kyocera Event Ear Piece Speaker Replacement, Remove the back assembly: 4 단계, 이미지 3/3
    • Pry the back assembly away from the body on all four sides of the phone.
    • Start prying at the top and work around.
    • Remove the buttons for the volume and power-this will allow for easier disassembly.
    • The back assembly is firmly attached to the body of the phone so removing it will require some force.
  5. Kyocera Event Ear Piece Speaker Replacement, Ear Piece Speaker: 5 단계, 이미지 1/3 Kyocera Event Ear Piece Speaker Replacement, Ear Piece Speaker: 5 단계, 이미지 2/3 Kyocera Event Ear Piece Speaker Replacement, Ear Piece Speaker: 5 단계, 이미지 3/3
    • Soldering required to complete replacement
    • Start by un-attaching the small olive colored chip from the plastic casing.
    • The chip is connected to the phone by a small orange wire. Keep the wire connected to the chip and the phone body while removing the chip from the black plastic casing.
    • Pry underneath the chip with the plastic opener until it pops off. Leave the orange wires attached.
  6. Kyocera Event Ear Piece Speaker Replacement: 6 단계, 이미지 1/3 Kyocera Event Ear Piece Speaker Replacement: 6 단계, 이미지 2/3 Kyocera Event Ear Piece Speaker Replacement: 6 단계, 이미지 3/3
    • Use tweezers to lift up the black plastic cover.
    • The cover will pop out. Set it aside.
  7. Kyocera Event Ear Piece Speaker Replacement: 7 단계, 이미지 1/3 Kyocera Event Ear Piece Speaker Replacement: 7 단계, 이미지 2/3 Kyocera Event Ear Piece Speaker Replacement: 7 단계, 이미지 3/3
    • Speaker is magnetized.
    • Use a metal object to lift the speaker out OR use tweezers to grab underneath the top corner of the speaker and lift/pry it out.
  8. Kyocera Event Ear Piece Speaker Replacement: 8 단계, 이미지 1/1
    • Unsolder the speaker wires from the phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
cmiller24
회원 가입일: 02/13/15
19 평판
안내서 1개 작성함
Ohio State, Team 1-2, Michaels Spring 2015 Ohio State, Team 1-2, Michaels Spring 2015 회원
OSU-MICHAELS-S15S1G2
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 12
전체 시간: 845
