주요 콘텐츠로 건너뛰기
Kyocera Event MicroSD Card Replacement
  1. Kyocera Event MicroSD Card Replacement, Battery: 1 단계, 이미지 1/3 Kyocera Event MicroSD Card Replacement, Battery: 1 단계, 이미지 2/3 Kyocera Event MicroSD Card Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event MicroSD Card Replacement: 2 단계, 이미지 1/1
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event MicroSD Card Replacement, Locate the SIM card: 3 단계, 이미지 1/1
    • The SIM card slot can be seen in the middle left of the photograph.
  4. Kyocera Event MicroSD Card Replacement, Open slot and remove card: 4 단계, 이미지 1/2 Kyocera Event MicroSD Card Replacement, Open slot and remove card: 4 단계, 이미지 2/2
    • The SD card slot can be opened and closed, as depicted by the tool.
    • The SD card itself slides into and out of the metal cover.
    • The gold tipped tines are what read the SD card along its bottom.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
graysonmensah
회원 가입일: 02/13/15
22 평판
안내서 1개 작성함
Ohio State, Team 1-4, Michaels Spring 2015 Ohio State, Team 1-4, Michaels Spring 2015 회원
OSU-MICHAELS-S15S1G4
3 회원들
안내서 4개 작성하였습니다
댓글 3개
That's the micro SD slot. That's not for a SIM card.
Carl Jr - 답글
What if there's no metal cover?
Michael ansley - 답글
That's for the sd card not the sim card
gasparesparza9 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 3,055
