소개
This guide will walk you through removing your phone battery and replacing it with a new one. After following this guide if your device will not power on, investigate charger, charger port, and power button.
도구
부품
부품은 필요하지 않습니다.
  1. Remove the back cover by prying from the gap above the charging port.
    • Remove the back cover by prying from the gap above the charging port.
  2. Pry the battery from the bottom of the phone to remove it.
    • Pry the battery from the bottom of the phone to remove it.
결론
cory pritchard
회원 가입일: 2018년 09월 21일
329 평판
안내서 2개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 27
전체 시간: 54
