1. Remove back  cover
    • Remove back cover
    • Pry from the gap above charger port as displayed.
  2. Remove battery
    • Remove battery
    • Use a PH00 screwdriver to remove the 6 screws from the mid-frame.
    • Removing the screws too carelessly can result in them being damaged or stripped.
    • Remove back panel trim
    • Back panel trim is fairly thin, be cautious when removing it.
    • Remove back panel
    • Pry the 4 corners off first
    • Remove power button with tweezers
결론
Haley Brown
회원 가입일: 2018년 09월 21일
183 평판
안내서 1개 작성함
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 35
전체 시간: 44
