주요 콘텐츠로 건너뛰기
Kyocera Hydro Life SD Card Replacement
필요한 것
  1. Kyocera Hydro Life SD Card Replacement, SD Card: 1 단계, 이미지 1/2 Kyocera Hydro Life SD Card Replacement, SD Card: 1 단계, 이미지 2/2
    • Open the back of the phone by prying the back cover off.
  2. Kyocera Hydro Life SD Card Replacement: 2 단계, 이미지 1/2 Kyocera Hydro Life SD Card Replacement: 2 단계, 이미지 2/2
    • Remove the battery by pulling up on the end.
  3. Kyocera Hydro Life SD Card Replacement: 3 단계, 이미지 1/1
    • Remove the SD Card by pushing in slightly and then releasing, allowing the card to slide out slightly and then removing it.
    • Place a new SD Card into this slot, making sure to line up the metal prongs.
결론
Rebecca Lamb
회원 가입일: 09/21/18
327 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 13
전체 시간: 127
