주요 콘텐츠로 건너뛰기
Kyocera Hydro Vibe Headphone Jack Replacement
필요한 것
  1. Kyocera Hydro Vibe Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 1/3 Kyocera Hydro Vibe Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 2/3 Kyocera Hydro Vibe Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 3/3
    • Pop the back plate off by using your hands or a spudger.
  2. Kyocera Hydro Vibe Headphone Jack Replacement: 2 단계, 이미지 1/3 Kyocera Hydro Vibe Headphone Jack Replacement: 2 단계, 이미지 2/3 Kyocera Hydro Vibe Headphone Jack Replacement: 2 단계, 이미지 3/3
    • Remove the trim from the phone by carefully prying it away using your hands.
  3. Kyocera Hydro Vibe Headphone Jack Replacement: 3 단계, 이미지 1/2 Kyocera Hydro Vibe Headphone Jack Replacement: 3 단계, 이미지 2/2
    • Remove six Phillips screws (screw length of 5.35 mm and screw head diameter of 2.95mm) on the back of the device using a Phillips #000 screwdriver.
  4. Kyocera Hydro Vibe Headphone Jack Replacement: 4 단계, 이미지 1/3 Kyocera Hydro Vibe Headphone Jack Replacement: 4 단계, 이미지 2/3 Kyocera Hydro Vibe Headphone Jack Replacement: 4 단계, 이미지 3/3
    • Remove the battery by popping it out of the phone by using your hands or the spudger to pry it up out of the case.
  5. Kyocera Hydro Vibe Headphone Jack Replacement: 5 단계, 이미지 1/2 Kyocera Hydro Vibe Headphone Jack Replacement: 5 단계, 이미지 2/2
    • Remove the inner plate from the phone using the spudger or your fingers.
  6. Kyocera Hydro Vibe Headphone Jack Replacement: 6 단계, 이미지 1/3 Kyocera Hydro Vibe Headphone Jack Replacement: 6 단계, 이미지 2/3 Kyocera Hydro Vibe Headphone Jack Replacement: 6 단계, 이미지 3/3
    • Remove the headphone jack using the spudger to push down on the jack to dislodge it from the phone.
    • Once the headphone jack is dislodged, you can disconnect the ribbon cable by carefully pulling it out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Katherine Pfeiffer
회원 가입일: 11/01/18
154 평판
안내서 1개 작성함
IUPUI, Team S3-G6, Harley Fall 2018 IUPUI, Team S3-G6, Harley Fall 2018 회원
IUPUI-HARLEY-F18S3G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 239
