주요 콘텐츠로 건너뛰기
Kyocera Hydro Vibe Internal Speaker Replacement
필요한 것
  1. Kyocera Hydro Vibe Internal Speaker Replacement, Internal Speaker: 1 단계, 이미지 1/3 Kyocera Hydro Vibe Internal Speaker Replacement, Internal Speaker: 1 단계, 이미지 2/3 Kyocera Hydro Vibe Internal Speaker Replacement, Internal Speaker: 1 단계, 이미지 3/3
    • Remove the back plate of the device by popping it off with your fingernail or a spudger.
  2. Kyocera Hydro Vibe Internal Speaker Replacement: 2 단계, 이미지 1/2 Kyocera Hydro Vibe Internal Speaker Replacement: 2 단계, 이미지 2/2
    • Remove six Phillips screws (screw length of 5.35 mm and screw head diameter of 2.95mm) on the back of the device using a Phillips #000 screwdriver.
  3. Kyocera Hydro Vibe Internal Speaker Replacement: 3 단계, 이미지 1/3 Kyocera Hydro Vibe Internal Speaker Replacement: 3 단계, 이미지 2/3 Kyocera Hydro Vibe Internal Speaker Replacement: 3 단계, 이미지 3/3
    • Remove the trim around the outside of the device by peeling it off with your hands.
  4. Kyocera Hydro Vibe Internal Speaker Replacement: 4 단계, 이미지 1/3 Kyocera Hydro Vibe Internal Speaker Replacement: 4 단계, 이미지 2/3 Kyocera Hydro Vibe Internal Speaker Replacement: 4 단계, 이미지 3/3
    • Remove battery using the spudger or your fingernails to pry the battery up out of the case.
  5. Kyocera Hydro Vibe Internal Speaker Replacement: 5 단계, 이미지 1/2 Kyocera Hydro Vibe Internal Speaker Replacement: 5 단계, 이미지 2/2
    • Now remove the rear frame, exposing the speaker. To remove the frame you can use the Spudger tool from the iFixit Tool kit or your hands.
  6. Kyocera Hydro Vibe Internal Speaker Replacement: 6 단계, 이미지 1/3 Kyocera Hydro Vibe Internal Speaker Replacement: 6 단계, 이미지 2/3 Kyocera Hydro Vibe Internal Speaker Replacement: 6 단계, 이미지 3/3
    • Remove the speaker from its location on the back frame using a spudger.
결론
Ben Lange
회원 가입일: 11/01/18
139 평판
안내서 1개 작성함
IUPUI, Team S3-G6, Harley Fall 2018 IUPUI, Team S3-G6, Harley Fall 2018 회원
IUPUI-HARLEY-F18S3G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 204
