주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kyocera Hydro Vibe Lock Button Replacement
필요한 것
  1. Kyocera Hydro Vibe Lock Button Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe Lock Button Replacement: 2 단계, 이미지 3개 중 1개 Kyocera Hydro Vibe Lock Button Replacement: 2 단계, 이미지 3개 중 2개 Kyocera Hydro Vibe Lock Button Replacement: 2 단계, 이미지 3개 중 3개
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Kyocera Hydro Vibe Lock Button Replacement, Trim: 3 단계, 이미지 1개 중 1개
    • Locate the screws holding the trim which are the four side screws on each corner.
    • Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
  4. Kyocera Hydro Vibe Lock Button Replacement: 4 단계, 이미지 2개 중 1개 Kyocera Hydro Vibe Lock Button Replacement: 4 단계, 이미지 2개 중 2개
    • Locate the clasps holding the trim in place.
    • You will need to insert the metal spudger through the bottom of the trim and slowly push upwards to release the clasps.
  5. Kyocera Hydro Vibe Lock Button Replacement: 5 단계, 이미지 1개 중 1개
    • The trim is flimsy.
    • This is what the trim will look like once removed.
  6. Kyocera Hydro Vibe Lock Button Replacement, Lock Button: 6 단계, 이미지 3개 중 1개 Kyocera Hydro Vibe Lock Button Replacement, Lock Button: 6 단계, 이미지 3개 중 2개 Kyocera Hydro Vibe Lock Button Replacement, Lock Button: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Once you have taken the trim apart, the lock button will be easily removable.
    • The lock button is located on the top of the phone.
    • Take the tweezers and remove the lock button.
결론
작성자
4다른 기여자 명과 함께
Kunal Patel
회원 가입일: 01/29/16
562 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 50
전체 시간: 666
