주요 콘텐츠로 건너뛰기
소개
This guide will walk readers through the steps toward replacing the SIM card.
부품
지정된 부품이 없습니다.
  1. Make sure that the device is turned off before beginning.
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. The large white component is the battery. Look for a small indentation under the arrow that says "LIFT." Place the plastic opening tool in the indentation and lift the battery out of the socket. Place the plastic opening tool in the indentation and lift the battery out of the socket.
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
    PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
  4. Locate the SIM card indicated by the arrows and picture.
    • Locate the SIM card indicated by the arrows and picture.
  5. Use the precision tweezer set to safely remove the SIM card. Use the precision tweezer set to safely remove the SIM card.
    • Use the precision tweezer set to safely remove the SIM card.
결론
Kunal Patel
회원 가입일: 2016년 01월 29일
550 평판
안내서 3개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 2
전체 시간: 371
