주요 콘텐츠로 건너뛰기
Kyocera Hydro Vibe Volume Button Replacement
필요한 것
  1. Kyocera Hydro Vibe Volume Button Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe Volume Button Replacement: 2 단계, 이미지 1/3 Kyocera Hydro Vibe Volume Button Replacement: 2 단계, 이미지 2/3 Kyocera Hydro Vibe Volume Button Replacement: 2 단계, 이미지 3/3
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Kyocera Hydro Vibe Volume Button Replacement, Trim: 3 단계, 이미지 1/1
    • Locate the screws holding the trim which are the four side screws on each corner.
    • Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
  4. Kyocera Hydro Vibe Volume Button Replacement: 4 단계, 이미지 1/2 Kyocera Hydro Vibe Volume Button Replacement: 4 단계, 이미지 2/2
    • Locate the clasps holding the trim in place.
    • You will need to insert the metal spudger through the bottom of the trim and slowly push upwards to release the clasps.
  5. Kyocera Hydro Vibe Volume Button Replacement: 5 단계, 이미지 1/1
    • The trim is flimsy.
    • This is what the trim will look like once removed.
  6. Kyocera Hydro Vibe Volume Button Replacement, Volume Button: 6 단계, 이미지 1/3 Kyocera Hydro Vibe Volume Button Replacement, Volume Button: 6 단계, 이미지 2/3 Kyocera Hydro Vibe Volume Button Replacement, Volume Button: 6 단계, 이미지 3/3
    • Once you have taken out the trim, the volume button will be easily removable.
    • Locate the volume button, if you are looking at the back of the phone (battery side) then it will be on the right side.
    • Take the tweezers and remove the button.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Juliane Vo
회원 가입일: 01/31/16
255 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 308
