주요 콘텐츠로 건너뛰기
Kyocera Marbl K127 Battery Replacement
필요한 것
  1. Kyocera Marbl K127 Battery Replacement, Remove the cover on the back of the phone.: 1 단계, 이미지 1/3 Kyocera Marbl K127 Battery Replacement, Remove the cover on the back of the phone.: 1 단계, 이미지 2/3 Kyocera Marbl K127 Battery Replacement, Remove the cover on the back of the phone.: 1 단계, 이미지 3/3
    • Place your thumbs on the pack of the phone and slide them in a downward motion to remove the cover.
  2. Kyocera Marbl K127 Battery Replacement, Remove the battery: 2 단계, 이미지 1/3 Kyocera Marbl K127 Battery Replacement, Remove the battery: 2 단계, 이미지 2/3 Kyocera Marbl K127 Battery Replacement, Remove the battery: 2 단계, 이미지 3/3
    • Use your index finger at the top of the battery and pull it towards your body.
결론
Brittany Mitchell
회원 가입일: 09/02/14
309 평판
안내서 3개 작성하였습니다
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-2, Stewart Fall 2014 회원
USFSM-STEWART-F14S1G2
3 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 4
전체 시간: 318
