주요 콘텐츠로 건너뛰기
Kyocera Marbl K127 Keyboard Replacement
필요한 것
  1. Kyocera Marbl K127 Keyboard Replacement, Remove the cover on the back of the phone.: 1 단계, 이미지 1/3 Kyocera Marbl K127 Keyboard Replacement, Remove the cover on the back of the phone.: 1 단계, 이미지 2/3 Kyocera Marbl K127 Keyboard Replacement, Remove the cover on the back of the phone.: 1 단계, 이미지 3/3
    • Place your thumbs on the pack of the phone and slide them in a downward motion to remove the cover.
  2. Kyocera Marbl K127 Keyboard Replacement, Remove the battery: 2 단계, 이미지 1/3 Kyocera Marbl K127 Keyboard Replacement, Remove the battery: 2 단계, 이미지 2/3 Kyocera Marbl K127 Keyboard Replacement, Remove the battery: 2 단계, 이미지 3/3
    • Use your index finger at the top of the battery and pull it towards your body.
  3. Kyocera Marbl K127 Keyboard Replacement, Remove the phone backing.: 3 단계, 이미지 1/3 Kyocera Marbl K127 Keyboard Replacement, Remove the phone backing.: 3 단계, 이미지 2/3 Kyocera Marbl K127 Keyboard Replacement, Remove the phone backing.: 3 단계, 이미지 3/3
    • Use the Y1 tri-wing screwdriver to remove the four 2.4mm screws and then pry the entire backing off of the phone including the black clip attached to the top of the motherboard.
  4. Kyocera Marbl K127 Keyboard Replacement, Remove the existing keyboard.: 4 단계, 이미지 1/3 Kyocera Marbl K127 Keyboard Replacement, Remove the existing keyboard.: 4 단계, 이미지 2/3 Kyocera Marbl K127 Keyboard Replacement, Remove the existing keyboard.: 4 단계, 이미지 3/3
    • Lift the motherboard away from you to locate the existing keyboard and remove it.
  5. Kyocera Marbl K127 Keyboard Replacement, Install the new keyboard.: 5 단계, 이미지 1/3 Kyocera Marbl K127 Keyboard Replacement, Install the new keyboard.: 5 단계, 이미지 2/3 Kyocera Marbl K127 Keyboard Replacement, Install the new keyboard.: 5 단계, 이미지 3/3
    • Hold the new keyboard in your hand facing you as it would look in your cell phone, lift the motherboard with your opposite hand, and then flip the keyboard face down and fit it in to place.
결론
Brittany Mitchell
회원 가입일: 09/02/14
309 평판
안내서 3개 작성하였습니다
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-2, Stewart Fall 2014 회원
USFSM-STEWART-F14S1G2
3 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 252
