메인 콘텐츠로 스킵하기
부품
지정된 부품이 없습니다.
  1. Wedge the opening device into the side crease of the phone. Wedge the opening device into the side crease of the phone.
    • Wedge the opening device into the side crease of the phone.
  2. Slide the opening device downward to dis-join the rear casing from the front casing. Continue around all edges. Slide the opening device downward to dis-join the rear casing from the front casing. Continue around all edges.
    • Slide the opening device downward to dis-join the rear casing from the front casing. Continue around all edges.
  3. Remove the back casing from the front casing. Force may be necessary.
    • Remove the back casing from the front casing. Force may be necessary.
결론
Erica
회원 가입일: 2011년 10월 14일
101 평판
안내서 3개 작성하였습니다
James Madison, Team 1-49, Allen Fall 2011 James Madison, Team 1-49, Allen Fall 2011 회원
JMU-ALLEN-F11S1G49
3 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 779
