주요 콘텐츠로 건너뛰기
Kyocera QCP-2035 Display Replacement
필요한 것
  1. Kyocera QCP-2035 Display Replacement, Remove Back Cover: 1 단계, 이미지 1/3 Kyocera QCP-2035 Display Replacement, Remove Back Cover: 1 단계, 이미지 2/3 Kyocera QCP-2035 Display Replacement, Remove Back Cover: 1 단계, 이미지 3/3
    • When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
    • Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
    • In 5 mm it will stop sliding.
  2. Kyocera QCP-2035 Display Replacement: 2 단계, 이미지 1/3 Kyocera QCP-2035 Display Replacement: 2 단계, 이미지 2/3 Kyocera QCP-2035 Display Replacement: 2 단계, 이미지 3/3
    • Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
    • Turn the phone over slowly. The battery will fall out on its own.
  3. Kyocera QCP-2035 Display Replacement: 3 단계, 이미지 1/3 Kyocera QCP-2035 Display Replacement: 3 단계, 이미지 2/3 Kyocera QCP-2035 Display Replacement: 3 단계, 이미지 3/3
    • Rotate the phone so the bottom is facing you. There is a small indent on the plastic face.
    • Using the tip of your fingernail or a spudger, pry the cover away from the rest of the phone.
    • Once the cover starts to part, keep separating until the top notches detach.
  4. Kyocera QCP-2035 Display Replacement: 4 단계, 이미지 1/3 Kyocera QCP-2035 Display Replacement: 4 단계, 이미지 2/3 Kyocera QCP-2035 Display Replacement: 4 단계, 이미지 3/3
    • With the cover plate separated, you will see (6) T6x11mm torx screws recessed in the white plastic.
    • Remove screws.
    • The white plastic face plate lifts right off, exposing the main board.
  5. Kyocera QCP-2035 Display Replacement, Display: 5 단계, 이미지 1/3 Kyocera QCP-2035 Display Replacement, Display: 5 단계, 이미지 2/3 Kyocera QCP-2035 Display Replacement, Display: 5 단계, 이미지 3/3
    • Lift the display straight up, by either grabbing it on it's sides, or sliding a pair of tweezers between the screen and the main board.
    • There are four straight plastic pins on the underside corners of the screen that hold it in place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Scott Whitney
회원 가입일: 01/21/15
301 평판
안내서 3개 작성하였습니다
USF Tampa, Team 5-3, Brown Winter 2015 USF Tampa, Team 5-3, Brown Winter 2015 회원
USFT-BROWN-W15S5G3
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 179
