주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kyocera Zio M6000 Digitizer Replacement
필요한 것
  1. Kyocera Zio M6000 Digitizer Replacement, Battery: 1 단계, 이미지 2개 중 1개 Kyocera Zio M6000 Digitizer Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Press down on the back of the phone, applying moderate pressure.
    • Slide the back casing down to separate it.
  2. Kyocera Zio M6000 Digitizer Replacement: 2 단계, 이미지 2개 중 1개 Kyocera Zio M6000 Digitizer Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the back casing to expose the battery.
    • Use a plastic spudger to lift the battery out using the battery's groove on its top left corner.
  3. Kyocera Zio M6000 Digitizer Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 Kyocera Zio M6000 Digitizer Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Remove the six 3.18 mm screws using a Phillips 00 screwdriver.
  4. Kyocera Zio M6000 Digitizer Replacement: 4 단계, 이미지 2개 중 1개 Kyocera Zio M6000 Digitizer Replacement: 4 단계, 이미지 2개 중 2개
    • Insert the flat end of the spudger between the front and back panels, and pry it apart by running the spudger along the side to further separate them.
    • Go all the way around, prying as you go, until the back casing completely separates from the rest of the phone.
  5. Kyocera Zio M6000 Digitizer Replacement: 5 단계, 이미지 3개 중 1개 Kyocera Zio M6000 Digitizer Replacement: 5 단계, 이미지 3개 중 2개 Kyocera Zio M6000 Digitizer Replacement: 5 단계, 이미지 3개 중 3개
    • Unclip the two flex cables -- a small one located on the left side on the lower half of the motherboard, and a longer one on the right side, higher up.
  6. Kyocera Zio M6000 Digitizer Replacement: 6 단계, 이미지 3개 중 1개 Kyocera Zio M6000 Digitizer Replacement: 6 단계, 이미지 3개 중 2개 Kyocera Zio M6000 Digitizer Replacement: 6 단계, 이미지 3개 중 3개
    • Pry out the earpiece speaker using the spudger.
    • Pry out the vibration motor using the spudger.
  7. Kyocera Zio M6000 Digitizer Replacement: 7 단계, 이미지 2개 중 1개 Kyocera Zio M6000 Digitizer Replacement: 7 단계, 이미지 2개 중 2개
    • Place the flat end of the spudger underneath the digitizer connector and pry it up to disconnect it.
  8. Kyocera Zio M6000 Digitizer Replacement: 8 단계, 이미지 3개 중 1개 Kyocera Zio M6000 Digitizer Replacement: 8 단계, 이미지 3개 중 2개 Kyocera Zio M6000 Digitizer Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the sticker to uncover the screws underneath.
    • Remove the six 1.59 mm screws using a Phillips 00 screwdriver.
  9. Kyocera Zio M6000 Digitizer Replacement: 9 단계, 이미지 3개 중 1개 Kyocera Zio M6000 Digitizer Replacement: 9 단계, 이미지 3개 중 2개 Kyocera Zio M6000 Digitizer Replacement: 9 단계, 이미지 3개 중 3개
    • Lift the bottom portion of the motherboard away from the front panel.
    • Do not forcefully pull the components apart as there is another connector on the underside of the motherboard attaching it to the panel.
    • Insert the flat end of the spudger in between the panel and motherboard to unfasten the connector.
  10. Kyocera Zio M6000 Digitizer Replacement, Digitizer: 10 단계, 이미지 3개 중 1개 Kyocera Zio M6000 Digitizer Replacement, Digitizer: 10 단계, 이미지 3개 중 2개 Kyocera Zio M6000 Digitizer Replacement, Digitizer: 10 단계, 이미지 3개 중 3개
    • Remove the two rubber pieces from the ends of the panel.
  11. Kyocera Zio M6000 Digitizer Replacement: 11 단계, 이미지 3개 중 1개 Kyocera Zio M6000 Digitizer Replacement: 11 단계, 이미지 3개 중 2개 Kyocera Zio M6000 Digitizer Replacement: 11 단계, 이미지 3개 중 3개
    • Remove the red Power button and green Talk button from the bottom of the casing.
    • Remove the trackball, also at the bottom of the casing.
  12. Kyocera Zio M6000 Digitizer Replacement: 12 단계, 이미지 3개 중 1개 Kyocera Zio M6000 Digitizer Replacement: 12 단계, 이미지 3개 중 2개 Kyocera Zio M6000 Digitizer Replacement: 12 단계, 이미지 3개 중 3개
    • Pry the bottom edge of the bezel with the flat end of the spudger.
    • Carefully run the spudger up the sides until the digitizer is free.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Scott Nguyen
회원 가입일: 09/16/15
522 평판
안내서 3개를 작성함
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 회원
USFSM-STEWART-F15S1G2
5 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 42
전체 시간: 597
