소개
If the phone has trouble reading your touch input to its touch screen, the digitizer may be damaged or broken. If that is the case, a replacement is in order. This guide will instruct you on how to safely take apart the device to change out the digitizer.
필요한 것
Press down on the back of the phone, applying moderate pressure.
Slide the back casing down to separate it.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
