주요 콘텐츠로 건너뛰기
LCD LG 37LF65 Capacitor replacement
필요한 것
  1. LCD LG 37LF65 Capacitor replacement, Open the case: 1 단계, 이미지 1/1
    • Power off and unplug your device before starting this repair.
    • Open the case carefully while loosing the marked srews.
  2. LCD LG 37LF65 Capacitor replacement, Replace the capacitors: 2 단계, 이미지 1/1
    • Check the power-board. If there are any blown-up capacitors, you should replace them.
    • For removing the capacitors, remove the board, take a soldering bolt and heat the solder points at the back of the board.
    • Insert the replacement capacitors and solder it. Check the poles!
  3. LCD LG 37LF65 Capacitor replacement, Testing capacitors: 3 단계, 이미지 1/1
    • If you are not sure about the condition of the capacitors you can prove it with a good measuring device after the expansion.
결론
Not all capacitors are need in any case. To reassemble your device, follow these instructions in reverse order.
다른 9명이 해당 안내서를 완성하였습니다.
eugl18
회원 가입일: 01/18/13
561 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 15
30일 전: 43
전체 시간: 13,375
