주요 콘텐츠로 건너뛰기
LERSTA Floor Lamp Screw Terminal Replacement
필요한 것
  1. LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: 1 단계, 이미지 2개 중 1개 LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: 1 단계, 이미지 2개 중 2개
    • Unplug the lamp.
  2. LERSTA Floor Lamp Screw Terminal Replacement: 2 단계, 이미지 1개 중 1개
    • Rotate the bulb counterclockwise to remove the light bulb.
  3. LERSTA Floor Lamp Screw Terminal Replacement: 3 단계, 이미지 1개 중 1개
    • Rotate the lamp shade counterclockwise.
  4. LERSTA Floor Lamp Screw Terminal Replacement: 4 단계, 이미지 1개 중 1개
    • Take the three parts aside after dismantling the lamp shade.
  5. LERSTA Floor Lamp Screw Terminal Replacement: 5 단계, 이미지 1개 중 1개
    • Dismantle the lamp shaft by rotating it counterclockwise.
  6. LERSTA Floor Lamp Screw Terminal Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 3 mm screws from the silver cover.
    • Pull down both the silver cover and the black screw terminal.
  7. LERSTA Floor Lamp Screw Terminal Replacement: 7 단계, 이미지 1개 중 1개
    • Separate the light bulb socket from the silver cover by pulling the silver metal hasp in right-downward direction towards the lamp shaft.
    • Exert force on the both left and right hand sides of the hasp and then pull the hasp downward.
  8. LERSTA Floor Lamp Screw Terminal Replacement: 8 단계, 이미지 1개 중 1개
    • Replace the old bulb socket with a newly-purchased one.
결론
Replacing the screw terminal of the floor lamp is relatively easy, but be cautious to deal with the step of the substitution of the light socket.
작성자
1다른 기여자 명과 함께
[deleted]
회원 가입일: 05/09/20
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 57
전체 시간: 1,441
