주요 콘텐츠로 건너뛰기
LG 1010 Front Cover Replacement
필요한 것
  1. LG 1010 Front Cover Replacement, Front  Cover: 1 단계, 이미지 1/2 LG 1010 Front Cover Replacement, Front  Cover: 1 단계, 이미지 2/2
    • Use a Spudger to remove the two front plastic covers to reveal screws.
  2. LG 1010 Front Cover Replacement: 2 단계, 이미지 1/1
    • Remove two screws using a Torx T6 screwdriver.
  3. LG 1010 Front Cover Replacement: 3 단계, 이미지 1/2 LG 1010 Front Cover Replacement: 3 단계, 이미지 2/2
    • Pry off the screen front cover with a small flathead screwdriver.
  4. LG 1010 Front Cover Replacement: 4 단계, 이미지 1/1
    • Insert a small flathead screwdriver into the hinge and separate hinge connection.
  5. LG 1010 Front Cover Replacement: 5 단계, 이미지 1/1
    • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
  6. LG 1010 Front Cover Replacement: 6 단계, 이미지 1/1
    • Remove remaining portion of the front case from the flexible circuit board.
    • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nicholas Schmidt
회원 가입일: 10/09/10
97 평판
안내서 7개 작성하였습니다
Cal Poly, Team 3-25, Regan Fall 2010 Cal Poly, Team 3-25, Regan Fall 2010 회원
CPSU-REGAN-F10S3G25
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,001
