주요 콘텐츠로 건너뛰기
LG 1010 LCD Screen Replacement
필요한 것
  1. LG 1010 LCD Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the cell phone and place face down on a flat surface.
  2. LG 1010 LCD Screen Replacement: 2 단계, 이미지 1/2 LG 1010 LCD Screen Replacement: 2 단계, 이미지 2/2
    • While sliding the gray tab up, lift battery up and away from the cell phone.
  3. LG 1010 LCD Screen Replacement: 3 단계, 이미지 1/3 LG 1010 LCD Screen Replacement: 3 단계, 이미지 2/3 LG 1010 LCD Screen Replacement: 3 단계, 이미지 3/3
    • Remove battery and set aside.
  4. LG 1010 LCD Screen Replacement, Front  Cover: 4 단계, 이미지 1/2 LG 1010 LCD Screen Replacement, Front  Cover: 4 단계, 이미지 2/2
    • Use a Spudger to remove the two front plastic covers to reveal screws.
  5. LG 1010 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Remove two screws using a Torx T6 screwdriver.
  6. LG 1010 LCD Screen Replacement: 6 단계, 이미지 1/2 LG 1010 LCD Screen Replacement: 6 단계, 이미지 2/2
    • Pry off the screen front cover with a small flathead screwdriver.
  7. LG 1010 LCD Screen Replacement: 7 단계, 이미지 1/1
    • Insert a small flathead screwdriver into the hinge and separate hinge connection.
  8. LG 1010 LCD Screen Replacement: 8 단계, 이미지 1/1
    • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
  9. LG 1010 LCD Screen Replacement: 9 단계, 이미지 1/1
    • Remove remaining portion of the front case from the flexible circuit board.
    • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
  10. LG 1010 LCD Screen Replacement, Back Cover: 10 단계, 이미지 1/2 LG 1010 LCD Screen Replacement, Back Cover: 10 단계, 이미지 2/2
    • Unscrew the four screws on the back case using a T6 Torx Screwdriver.
  11. LG 1010 LCD Screen Replacement: 11 단계, 이미지 1/2 LG 1010 LCD Screen Replacement: 11 단계, 이미지 2/2
    • Pull the back cover straight off the phone using your thumb and forefinger.
  12. LG 1010 LCD Screen Replacement, Keypad: 12 단계, 이미지 1/1
    • Pry off circuit board with a flathead screwdriver.
  13. LG 1010 LCD Screen Replacement: 13 단계, 이미지 1/1
    • Pull out flexible keypad.
  14. LG 1010 LCD Screen Replacement, LCD Screen: 14 단계, 이미지 1/1
    • The phone should now look like the picture to the left.
  15. LG 1010 LCD Screen Replacement: 15 단계, 이미지 1/2 LG 1010 LCD Screen Replacement: 15 단계, 이미지 2/2
    • Locate and detach the ribbon cable from circuit board.
  16. LG 1010 LCD Screen Replacement: 16 단계, 이미지 1/2 LG 1010 LCD Screen Replacement: 16 단계, 이미지 2/2
    • Remove the LCD Screen from the phone case and replace with a new LCD screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nicholas Schmidt
회원 가입일: 10/09/10
97 평판
안내서 7개 작성하였습니다
Cal Poly, Team 3-25, Regan Fall 2010 Cal Poly, Team 3-25, Regan Fall 2010 회원
CPSU-REGAN-F10S3G25
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 949
