주요 콘텐츠로 건너뛰기
LG 305C Camera Replacement
필요한 것
  1. LG 305C Camera Replacement, Battery: 1 단계, 이미지 1/1
    • Pry open the back case on the device with a plastic opening tool and remove it.
  2. LG 305C Camera Replacement: 2 단계, 이미지 1/1
    • Pry the battery out of the device with a plastic opening tool and remove it.
  3. LG 305C Camera Replacement, MicroSD card: 3 단계, 이미지 1/1
    • Dislodge the microSD card from the microSD card slot using your index finger and remove it.
  4. LG 305C Camera Replacement, Internal Casing: 4 단계, 이미지 1/1
    • Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
  5. LG 305C Camera Replacement: 5 단계, 이미지 1/1
    • Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
  6. LG 305C Camera Replacement: 6 단계, 이미지 1/1
    • Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
  7. LG 305C Camera Replacement: 7 단계, 이미지 1/1
    • Pry open the top part of the internal casing with the plastic opening tool and remove it.
  8. LG 305C Camera Replacement, Motherboard: 8 단계, 이미지 1/1
    • Pry the screen from the internal circuit board with a plastic opening tool and remove it.
  9. LG 305C Camera Replacement, Camera: 9 단계, 이미지 1/1
    • Pry the camera from the internal circuit board with the plastic opening tool and remove it.
  10. LG 305C Camera Replacement: 10 단계, 이미지 1/1
    • Detach the camera completely by using the spudger tool to poke through the camera attachment holes.
결론
Ashley Kidwell
회원 가입일: 03/20/18
427 평판
안내서 5개 작성하였습니다
IUPUI, Team S6-G1, Baechle Spring 2018 IUPUI, Team S6-G1, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S6G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 160
