주요 콘텐츠로 건너뛰기
LG 32CS560 Power Supply Board Replacement
필요한 것
  1. LG 32CS560 Power Supply Board Replacement, Prepare your LG 32CS560 for disassembly: 1 단계, 이미지 2개 중 1개 LG 32CS560 Power Supply Board Replacement, Prepare your LG 32CS560 for disassembly: 1 단계, 이미지 2개 중 2개
    • Lay the TV face down on a soft surface
    • Remove the base of the TV by unscrewing the 4 base screws.
    • There is no base on the picture, the position of the base is marked whit the red box.
  2. LG 32CS560 Power Supply Board Replacement, Disassemble the LG32CS560: 2 단계, 이미지 2개 중 1개 LG 32CS560 Power Supply Board Replacement, Disassemble the LG32CS560: 2 단계, 이미지 2개 중 2개
    • Remove the 15 Phillips head screws on the back of the TV.
    • Carefully remove the black plastic back panel of the TV to expose the electronics inside
  3. LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: 3 단계, 이미지 3개 중 1개 LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: 3 단계, 이미지 3개 중 2개 LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: 3 단계, 이미지 3개 중 3개
    • Carefully disconnect the three wire bundles attached to the power supply.
    • Remove the four screws holding the power supply in place.
    • Now you can lift out the Power Supply Board.
    • If the black cylindrical component marked with yellow seems to have expanded or is leaking liquid or goo, then the power supply board is definitely bad.
결론
다른 24명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Coyt Barringer
회원 가입일: 10/11/14
707 평판
안내서 1개를 작성함
USF Tampa, Team 1-3, Donnelly Fall 2014 USF Tampa, Team 1-3, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G3
1 회원
안내서 2개를 작성함
댓글 2개
preciso duma destas power bord como fazer para ter
brun mendes - 답글
You should discharge the 'black cylindrical component' before attempting this. That component is a capacitor which can store excess electrical charge.
Danny - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 47
지난 30일: 167
전체 시간: 46,176
