주요 콘텐츠로 건너뛰기
LG 440G Logic Board Replacement
필요한 것
  1. LG 440G Logic Board Replacement, Turn off phone.: 1 단계, 이미지 1/1
    • Turn the device off.
    • To do so, press and hold the red button.
  2. LG 440G Logic Board Replacement, Flip phone.: 2 단계, 이미지 1/1
    • Flip the phone over.
  3. LG 440G Logic Board Replacement, Rear cover removal.: 3 단계, 이미지 1/1
    • Slide the rear cover downward
    • Lift it off to access the battery
  4. LG 440G Logic Board Replacement, Removal of battery.: 4 단계, 이미지 1/1
    • Locate the small rounded recess to get access to the battery
    • Gently, lift the battery
  5. LG 440G Logic Board Replacement, Unscrew six screws along edges of casing: 5 단계, 이미지 1/1
    • Use a Phillips #00 screw driver to remove six screws.
    • Save screws for reassembly.
  6. LG 440G Logic Board Replacement, Lift casing cover: 6 단계, 이미지 1/2 LG 440G Logic Board Replacement, Lift casing cover: 6 단계, 이미지 2/2
    • Run the plastic opening tool along the edge of the phone to release the casing cover.
    • Lift the casing cover.
  7. LG 440G Logic Board Replacement, Remove rectangular piece (with orange tape attached): 7 단계, 이미지 1/2 LG 440G Logic Board Replacement, Remove rectangular piece (with orange tape attached): 7 단계, 이미지 2/2
    • Use the plastic opening tool or fingernail to lift the rectangular piece up. The piece can be identified by the orange tape attached to it.
  8. LG 440G Logic Board Replacement, Dislodge logic board: 8 단계, 이미지 1/1
    • Dislodge the logic board using a plastic opening tool.
  9. LG 440G Logic Board Replacement, Lift logic board out: 9 단계, 이미지 1/1
    • Remove the logic board by lifting up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
JP Belanger
회원 가입일: 02/17/15
225 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-1, Buehl Winter 2015 Ohio State, Team 1-1, Buehl Winter 2015 회원
OSU-BUEHL-W15S1G1
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Hi, do you know how to take the microphone out without damaging the functionality of the phone? It’s attached to a ribbon that is soldered on. Thanks!
Kobalt000 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 969
