주요 콘텐츠로 건너뛰기
LG A275 Motherboard Replacement
필요한 것
  1. LG A275 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Before starting this project we need to power down the phone, remove the back cover, take out the battery.
    • Have the device powered down to reduce the risk of damaging the device.
  2. LG A275 Motherboard Replacement: 2 단계, 이미지 1/2 LG A275 Motherboard Replacement: 2 단계, 이미지 2/2
    • Very carefully slide the plastic prying tool along the sides of the phone to unhinge the locks.
    • If you have to use a metal one be careful not to slide it in too carefully as you might damage the sensors.
  3. LG A275 Motherboard Replacement: 3 단계, 이미지 1/3 LG A275 Motherboard Replacement: 3 단계, 이미지 2/3 LG A275 Motherboard Replacement: 3 단계, 이미지 3/3
    • Now that are device is open we need to remove the old mother board and replace it with a new one.
    • When putting the new one in be careful of the small sensor on the bottom as it can come off.
    • If this gets damaged the keyboard will not be able to be read any longer.
결론
Alec Pierce
회원 가입일: 03/26/16
231 평판
안내서 2개 작성하였습니다
IUPUI, Team 2-2, Wilson Spring 2016 IUPUI, Team 2-2, Wilson Spring 2016 회원
IUPUI-WILSON-S16S2G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 363
