주요 콘텐츠로 건너뛰기
LG A275 Screen Replacement
필요한 것
  1. LG A275 Screen Replacement, Replacing the screen: 1 단계, 이미지 2개 중 1개 LG A275 Screen Replacement, Replacing the screen: 1 단계, 이미지 2개 중 2개
    • In order to begin replacing your screen, you should first power down your device and remove the battery.
  2. LG A275 Screen Replacement, Unhinging the screen: 2 단계, 이미지 2개 중 1개 LG A275 Screen Replacement, Unhinging the screen: 2 단계, 이미지 2개 중 2개
    • Take a very thin plastic/ metal prying tool and gently work your way around the phone. You should hear popping sounds as each lock is opened. Be very careful as you pry open the case as you could damage the LCD/Motherboard.
    • Hearing popping is a normal sound. You are not breaking your phone. You are simply popping the seals for the first time.
  3. LG A275 Screen Replacement, Putting the New Screen on: 3 단계, 이미지 3개 중 1개 LG A275 Screen Replacement, Putting the New Screen on: 3 단계, 이미지 3개 중 2개 LG A275 Screen Replacement, Putting the New Screen on: 3 단계, 이미지 3개 중 3개
    • Take your new screen and place it onto the front of the phone. Very gently apply pressure until you here the locks click into place.
    • Make sure all of your locking pins line up on your phone or it will not close all the way.
    • Be careful when removing the old cover. It could have jagged pieces of glass/ plastic.
결론
작성자
6다른 기여자 명과 함께
Nicole
회원 가입일: 02/13/16
237 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 453
