주요 콘텐츠로 건너뛰기
LG A275 Vibrator Replacement
필요한 것
  1. 주의: 1-3 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    LG A275 Vibrator Replacement, Battery: 1 단계, 이미지 1/2 LG A275 Vibrator Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the phone upside down so that the bottom of the back is facing you.
  2. LG A275 Vibrator Replacement, Remove cover: 2 단계, 이미지 1/2 LG A275 Vibrator Replacement, Remove cover: 2 단계, 이미지 2/2
    • Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off.
  3. LG A275 Vibrator Replacement: 3 단계, 이미지 1/1
    • Gently remove the battery from the device.
  4. LG A275 Vibrator Replacement, Vibrator: 4 단계, 이미지 1/3 LG A275 Vibrator Replacement, Vibrator: 4 단계, 이미지 2/3 LG A275 Vibrator Replacement, Vibrator: 4 단계, 이미지 3/3
    • Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone.
    • Be careful when using the plastic opening tool not to brute force the phone open, the plastics are fragile.
  5. LG A275 Vibrator Replacement: 5 단계, 이미지 1/2 LG A275 Vibrator Replacement: 5 단계, 이미지 2/2
    • After separating the two plastic halves of the phone, take the plastic that does not have the motherboard attached to it. The plastic has a small yellow component with a lob-sided magnet within it. This is the vibrator of the phone, pull this piece out with your hand. This piece is free floating and will simply drop out.
결론
To reassemble your device, follow these instructions in reverse order after placing in the new vibrator.
Nathanael Knight
회원 가입일: 03/27/18
181 평판
안내서 2개 작성하였습니다
IUPUI, Team S3-G1, Harley Spring 2018 IUPUI, Team S3-G1, Harley Spring 2018 회원
IUPUI-HARLEY-S18S3G1
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 130
