주요 콘텐츠로 건너뛰기
LG Aristo MS210 Front and Rear Camera Replacement
필요한 것
  1. LG Aristo MS210 Front and Rear Camera Replacement, Battery: 1 단계, 이미지 3개 중 1개 LG Aristo MS210 Front and Rear Camera Replacement, Battery: 1 단계, 이미지 3개 중 2개 LG Aristo MS210 Front and Rear Camera Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Insert the spudger into the notch on the bottom left side of the phone.
    • Apply light pressure to remove the back cover.
  2. LG Aristo MS210 Front and Rear Camera Replacement: 2 단계, 이미지 2개 중 1개 LG Aristo MS210 Front and Rear Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the spudger into the notch located on the bottom middle of the battery.
    • Apply light pressure to remove the battery.
  3. LG Aristo MS210 Front and Rear Camera Replacement, Command Button: 3 단계, 이미지 3개 중 1개 LG Aristo MS210 Front and Rear Camera Replacement, Command Button: 3 단계, 이미지 3개 중 2개 LG Aristo MS210 Front and Rear Camera Replacement, Command Button: 3 단계, 이미지 3개 중 3개
    • Use the PH000 bit unscrew the ten 3.4mm screws as highlighted.
    • Use the spudger to remove the inner shell.
    • Flip the inner shell over to expose the clips holding the command button.
  4. LG Aristo MS210 Front and Rear Camera Replacement: 4 단계, 이미지 3개 중 1개 LG Aristo MS210 Front and Rear Camera Replacement: 4 단계, 이미지 3개 중 2개 LG Aristo MS210 Front and Rear Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Use the spudger disconnect the three clips holding in the command button as highlighted.
    • Remove the command button.
  5. LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: 5 단계, 이미지 3개 중 1개 LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: 5 단계, 이미지 3개 중 2개 LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: 5 단계, 이미지 3개 중 3개
    • Use the spudger to disconnect the ZIF connector securing the front-facing camera.
  6. LG Aristo MS210 Front and Rear Camera Replacement: 6 단계, 이미지 3개 중 1개 LG Aristo MS210 Front and Rear Camera Replacement: 6 단계, 이미지 3개 중 2개 LG Aristo MS210 Front and Rear Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Use the spudger disconnect the ZIF connector securing the back-facing camera.
  7. LG Aristo MS210 Front and Rear Camera Replacement: 7 단계, 이미지 1개 중 1개
    • Remove both the front and back facing cameras.
결론
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 18
전체 시간: 289
