주요 콘텐츠로 건너뛰기
LG BP220 Power Cord Replacement
필요한 것
  1. LG BP220 Power Cord Replacement, Power Cord: 1 단계, 이미지 1/2 LG BP220 Power Cord Replacement, Power Cord: 1 단계, 이미지 2/2
    • Ensure the device is unplugged to prevent shocks.
    • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
    • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
  2. LG BP220 Power Cord Replacement: 2 단계, 이미지 1/3 LG BP220 Power Cord Replacement: 2 단계, 이미지 2/3 LG BP220 Power Cord Replacement: 2 단계, 이미지 3/3
    • Beware of the capacitors as they may shock you when touched.
    • Detach the power supply cord from the brown logic board by pushing the locking clip on the connector, and pulling out.
    • The connector may be difficult to remove. Wiggling it while pulling out may help release it.
    • Remove the power cord from the panel by carefully sliding it upwards from its seating.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Bart Quicho
회원 가입일: 01/13/15
463 평판
안내서 3개 작성하였습니다
UW Tacoma, Team 1-1, Rose Winter 2015 UW Tacoma, Team 1-1, Rose Winter 2015 회원
UWT-ROSE-W15S1G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 2,614
