주요 콘텐츠로 건너뛰기
LG CG180 Display Replacement
필요한 것
  1. LG CG180 Display Replacement, Battery: 1 단계, 이미지 1/1
    • Power down the cell phone by pressing and holding down the red "end call" button.
  2. LG CG180 Display Replacement: 2 단계, 이미지 1/1
    • Turn the phone screen-down so you are looking at the back cover.
  3. LG CG180 Display Replacement: 3 단계, 이미지 1/2 LG CG180 Display Replacement: 3 단계, 이미지 2/2
    • Slide the back cover down using your finger to remove the cover from the phone.
  4. LG CG180 Display Replacement: 4 단계, 이미지 1/1
    • Place your finger at the top of the battery in small gap.
  5. LG CG180 Display Replacement: 5 단계, 이미지 1/1
    • Press downward while pulling outward to remove the battery.
  6. LG CG180 Display Replacement, Hardshell Case: 6 단계, 이미지 1/1
    • Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
  7. LG CG180 Display Replacement: 7 단계, 이미지 1/1
    • Insert a plastic opening tool in the seam.
  8. LG CG180 Display Replacement: 8 단계, 이미지 1/2 LG CG180 Display Replacement: 8 단계, 이미지 2/2
    • Run the tool along the seam to release all the tabs.
  9. LG CG180 Display Replacement: 9 단계, 이미지 1/2 LG CG180 Display Replacement: 9 단계, 이미지 2/2
    • Pull the phone back cover off once all the tabs are released.
  10. LG CG180 Display Replacement: 10 단계, 이미지 1/1
    • Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
  11. LG CG180 Display Replacement: 11 단계, 이미지 1/1
    • The hardshell case is separated from the rest of the phone.
  12. LG CG180 Display Replacement, Keypad: 12 단계, 이미지 1/2 LG CG180 Display Replacement, Keypad: 12 단계, 이미지 2/2
    • Separate keypad from circuit board by turning it upside down and allowing it to fall off.
  13. LG CG180 Display Replacement, Display: 13 단계, 이미지 1/1
    • Place the circuit board with the display facing downward.
  14. LG CG180 Display Replacement: 14 단계, 이미지 1/1
    • Use thumb to release both white clips at the top of the circuit board.
    • Be careful with the display because it is still attached by electrical tape.
  15. LG CG180 Display Replacement: 15 단계, 이미지 1/2 LG CG180 Display Replacement: 15 단계, 이미지 2/2
    • Once both clips are released, turn over the circuit board so that the display is facing upward.
    • Carefully lift the display from the left side and open to the right.
  16. LG CG180 Display Replacement: 16 단계, 이미지 1/1
    • Carefully remove the electrical tape from the display.
  17. LG CG180 Display Replacement: 17 단계, 이미지 1/1
    • The display is disconnected from the circuit board.
결론
Alex Jacobs
회원 가입일: 01/21/10
5 평판
안내서 4개 작성하였습니다
Cal Poly, Team 14-42, Regan Winter 2010 Cal Poly, Team 14-42, Regan Winter 2010 회원
CPSU-REGAN-W10S14G42
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 14
전체 시간: 1,752
