주요 콘텐츠로 건너뛰기
LG CG225 Keyboard Replacement
필요한 것
  1. LG CG225 Keyboard Replacement, Rear Cover: 1 단계, 이미지 1/1
    • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
  2. LG CG225 Keyboard Replacement: 2 단계, 이미지 1/1
    • Remove a single Phillips #00 screw from beneath the cover.
  3. LG CG225 Keyboard Replacement: 3 단계, 이미지 1/1
    • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
  4. LG CG225 Keyboard Replacement, Motherboard: 4 단계, 이미지 1/1
    • Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
  5. LG CG225 Keyboard Replacement: 5 단계, 이미지 1/1
    • Using a small plastic opening tool, remove the motherboard.
  6. LG CG225 Keyboard Replacement, Keyboard: 6 단계, 이미지 1/1
    • Using your fingers, remove the plastic keyboard.
    • Loose buttons will sometimes fall off of the keyboard when it is removed.
결론
Mackenzie
회원 가입일: 02/13/14
1 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-3, Meza Spring 2014 Ohio State, Team 1-3, Meza Spring 2014 회원
OSU-MEZA-S14S1G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 287
