주요 콘텐츠로 건너뛰기
LG CG225 Motherboard Replacement
필요한 것
  1. LG CG225 Motherboard Replacement, Rear Cover: 1 단계, 이미지 1/1
    • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
  2. LG CG225 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove a single Phillips #00 screw from beneath the cover.
  3. LG CG225 Motherboard Replacement: 3 단계, 이미지 1/1
    • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
  4. LG CG225 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/1
    • Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
  5. LG CG225 Motherboard Replacement: 5 단계, 이미지 1/1
    • Using a small plastic opening tool, remove the motherboard.
결론
Darlena
회원 가입일: 02/11/14
219 평판
안내서 3개 작성하였습니다
Ohio State, Team 1-2, Buehl Spring 2014 Ohio State, Team 1-2, Buehl Spring 2014 회원
OSU-BUEHL-S14S1G2
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 139
