주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide will walk you through the steps to remove the motherboard from your LG CU400. It will help remove the battery, the lower half casing, and the actual removal of the motherboard from the phone casing. Before doing this, be aware that you will be unable to use your phone until the replacement is complete. You should also be careful when handling the motherboard because it has delicate wires extending from it.
  1. Push the button labeled 'PUSH' on the rear cover. Push the button labeled 'PUSH' on the rear cover.
    • Push the button labeled 'PUSH' on the rear cover.
  2. Slide the rear cover towards you. Slide the rear cover towards you. Slide the rear cover towards you.
    • Slide the rear cover towards you.
  3. To remove the battery, grasp the top front edge of the battery and pull the battery away from the phone. When installing the new battery, have the metal contacts of the phone match up with the metal contacts of the battery.
    • To remove the battery, grasp the top front edge of the battery and pull the battery away from the phone.
    • When installing the new battery, have the metal contacts of the phone match up with the metal contacts of the battery.
  4. Remove the sim card by sliding the card out from under the retainer using either your fingers or a spudger. Remove the sim card by sliding the card out from under the retainer using either your fingers or a spudger.
    • Remove the sim card by sliding the card out from under the retainer using either your fingers or a spudger.
  5. Remove the rubber covers in the highlighted locations using a metal spudger. Remove the rubber covers in the highlighted locations using a metal spudger.
    • Remove the rubber covers in the highlighted locations using a metal spudger.
  6. 필수 도구 키트
    최고의 소형 키트에서 가장 유용한 도구.
    지금 쇼핑하기
    필수 도구 키트
    지금 쇼핑하기
  7. Remove the six 3mm #000 flat Phillips head screws from the back of the phone using a Phillips #000 Screwdriver. Remove the six 3mm #000 flat Phillips head screws from the back of the phone using a Phillips #000 Screwdriver.
    • Remove the six 3mm #000 flat Phillips head screws from the back of the phone using a Phillips #000 Screwdriver.
  8. Remove the headphone jack cover with your finger or metal spudger. Remove the headphone jack cover with your finger or metal spudger.
    • Remove the headphone jack cover with your finger or metal spudger.
  9. Insert the metal spudger between the keypad assembly and back cover assembly and pry the two assemblies apart. Pry gently as to not break the plastic clips that hold the two assemblies together. Work your way around the perimeter of the phone with the metal spudger to separate the two assemblies.
    • Insert the metal spudger between the keypad assembly and back cover assembly and pry the two assemblies apart.
    • Pry gently as to not break the plastic clips that hold the two assemblies together.
    • Work your way around the perimeter of the phone with the metal spudger to separate the two assemblies.
  10. Once you have worked your way around the perimeter of the phone, you will have access to the components in the bottom half assembly. Once you have worked your way around the perimeter of the phone, you will have access to the components in the bottom half assembly.
    • Once you have worked your way around the perimeter of the phone, you will have access to the components in the bottom half assembly.
  11. You should notice that the number pad is loose and can simply be taken out of the open phone casing. You should notice that the number pad is loose and can simply be taken out of the open phone casing. You should notice that the number pad is loose and can simply be taken out of the open phone casing.
    • You should notice that the number pad is loose and can simply be taken out of the open phone casing.
  12. Using the spudger, start to gently pry the motherboard from the back of the phone and work your way around the perimeter of the motherboard. There are copper ribbon cables connected to each side of the motherboard leading to the buttons for volume control and the camera that need slid out of the phone casing as the motherboard is being removed.
    • Using the spudger, start to gently pry the motherboard from the back of the phone and work your way around the perimeter of the motherboard.
    • There are copper ribbon cables connected to each side of the motherboard leading to the buttons for volume control and the camera that need slid out of the phone casing as the motherboard is being removed.
    • There are three in total, but do not remove the top one from the phone casing yet.
  13. Once the motherboard is not locked in place it will still be attached to the back phone casing by two wires, red and black, twisted together.
    • Once the motherboard is not locked in place it will still be attached to the back phone casing by two wires, red and black, twisted together.
    • Use tweezers to grab the black piece that these wires are attached to and simply pull it off the motherboard.
    • You may need to flip the phone over so that the screen is facing down. Feel free to move the keypad assembly to the closed position for this step.
  14. Remove the display ribbon cable from the back of the motherboard using tweezers.
    • Remove the display ribbon cable from the back of the motherboard using tweezers.
    • Make sure to lift it so that you are pulling the entire thing off at once and not pulling off the flat piece at an angle.
  15. Use tweezers to remove the top ribbon cable, mentioned in step 11, from the hinge area.
    • Use tweezers to remove the top ribbon cable, mentioned in step 11, from the hinge area.
  16. Grasp either side of the motherboard and gently lift it away from the phone casing. The motherboard should be completely free of the phone casing, and you should have what is shown in the pictures. The motherboard should be completely free of the phone casing, and you should have what is shown in the pictures.
    • Grasp either side of the motherboard and gently lift it away from the phone casing.
    • The motherboard should be completely free of the phone casing, and you should have what is shown in the pictures.
결론
Ross Brown
회원 가입일: 2016년 10월 03일
290 평판
안내서 2개 작성하였습니다
IUPUI, Team 1-3, Harley Fall 2016 IUPUI, Team 1-3, Harley Fall 2016 회원
IUPUI-HARLEY-F16S1G3
4 회원들
안내서 14개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 84
